i have this one from the beginning, been wearing it to much in my younger years
so time to clean it up.
now it was full off scuffs so i dismantled it. Not easy.
as you see..it's a gold bezel now...i wanted to clean the besel and replate it with nickel and i found a nice golden layer under it.
so i kept it..another make-over
Memo - Will store up to 100 memos (internet e-mail addresses, Phone numbers etc.) Up to 60 English characters each.
Random messages. There are over 45 pre-programmed greetings and proverbs are . A different message automatically scrolls across the screen every 10 minutes or when the front button is pressed.
Programmed message 10 messages, of up to 60 English characters can be programmed to display on a designated date. When left in this mode, the selected message will automatically scroll every 10 minutes.
Stopwatch - After 10 hours will continue measuring from '00' up to 100 hours, then reset automaticaly to '00'.
Data stored even when battery needs replacement.
Time Calendar up to the year 2047 Residual memory display Alarm 24 hour and 3 single time alarms that can be engaged and disengaged independently Battery life indicator
Horizontal or vertical display
