It is currently 21 Jun 2026, 12:36
Mid 80's model Casio
Dch48
Post29 Apr 2012, 23:56
In addition to the A158W model I posted I own a mid 80's vintage model S002 that has the stopwatch, a countdown timer, 24/12h time, and dual time zone features. It still runs like it did when my Father bought it in the mid 80's. I got it when he passed away in 1992 and have worn it very extensively since then. It is not in perfect shape with a cracked crystal and a couple of areas under the crystal that look like maybe condensation that I don't know how to get rid of. I just put a new CR2325 battery in it to make the display a little darker but it was still running on the last replacement from about 6 years ago.
Re: Mid 80's model Casio
Post01 May 2012, 20:40
thats an ideal watch to learn some stuff about revive it to new.
you need differend sanding paper.
you need a new glass
you need some new polarisers.
those casio litiums keep there value..so it's worth it.
check out the forum...all you need is here...if you loose track, give us a yell.
Dch48
Post01 May 2012, 22:45
I have no idea what a polarizer is or what it does. I did search the forums a bit and get that it's a film over the LCD panel? How would I go about replacing that or even getting a replacement in the first place? The same thing goes for the glass. My knowledge only extends to changing a battery and cleaning the contacts for the buttons and levers under them and that's all I feel confident with. I had a very hard time getting the back off and finally used a tool called a Snappy Watch Case Opener which finally popped it off. The crack in the crystal came from the last battery change before this one. A local jeweler opened the case but didn't have the right battery. I bought the battery at Radio Shack and put it in but in the process of trying to snap the caseback on, I cracked the glass. My eyes are not that great now at 63 and my hands have never been steady. Even as a youngster I couldn't take non blurred photographs to save my life.
If the watch is going to be restored, I'm sure I'm not the one to do it. I have tried to work on mechanical watches before and anything past just adjusting the regulator has always ended in complete disaster and a then completely non-functional timepiece. Any advice or help would be greatly appreciated.
Post02 May 2012, 15:33
then you have to keep it as it is or sell it. It need a bit of work if you want to restore it.
and yes..it will take some searching and reading the forum to find all your answers for restorations, but it's all here.
Dch48
Post02 May 2012, 23:58
I'll just keep it like it is. It runs accurately and can be read in a good light without problems. It's actually become my beater watch that I wear while doing yardwork and mowing the lawn. Now, if somebody would be willing to take it on as a project, I'd be willing to pay a reasonable amount to have it restored.
