It is currently 17 Jun 2026, 14:20
Seiko M354 5020 problem
Post10 Jan 2013, 21:52
Hi....i have this nos seiko m354 but the lcd panel appear very blur and with rainbow effect....so i decided to change the film with new one....
The rainbow disappear but the lcd is still blur ..in the time section only the digitis of the day(upper left) appear very crisp but the time is very blur....also the calendar function is blur....do you have any tips for this dual layer lcd panel...could be a contact problem?Is this a common problem in this model?
I try also a second lcd panel and the problem is the same....
Re: Seiko M354 5020 problem
Post11 Jan 2013, 14:12
Hi Simone,
i have a few watches with the same problem.
I think that it's losing power somewhere. I don't know where.
till now, nobody knows the answer!
Post11 Jan 2013, 14:47
Kasper wrote:Hi Simone,
Losing power?mmmm....but where?
Could be a bad contact between the zebra and the board?
Seiko&Casio Lcd's
Post12 Jan 2013, 00:39
I had a similar problem, not all the digits light up with the same strength, some were faded ,others were stronger.
What i did was cleaning the zebra strips and contacts on the circuit board, and after that it was a bit better.
You might want to place a new and good brand battery,
I had some batteries of unknown brands that could not deliver a good enough current, so when i pushed the light button the digits would fade, do the digits stay on or do they fade when the light button is pushed on your watch, simone ?
Also, these lcd panels are known to have fade issues, you can never get it out completely is my experience.
Post12 Jan 2013, 13:07
Seiko&Casio Lcd's wrote:I had a similar problem, not all the digits light up with the same strength, some were faded ,others were stronger.
Hi friend...when i push the light button the digits stay on...i think that the problem is the current
Seiko&Casio Lcd's
Post12 Jan 2013, 16:24
In that case i would try to clean the contacts on the board and the zebra strips. ;-)
