It is currently 01 Mar 2026, 14:41
The Ventura Code?
your_man_in_Hamburg
The Ventura Code?
Post18 Feb 2010, 23:45
Hi gang!
I suddenly discovered the following curious "feature" tucked away in my v-tec alpha:
I first push the scroll wheel, roll down to second time zone, push once more to swap T1 and T2, and then roll up to see T2 where T1 used to be, that is, in the first row...
...but hey, what's there on the second row???
Local time is 22:41:22, today is 2010-02-18 and the second row displays 030127. Beats me. It does not correspond to the alarm setting, nor any stored chronograph results. It's just there.
Any ideas?
[/list]
: The Ventura Code?
Post19 Feb 2010, 01:29
It's the date for T2.
You can set the date separately for both time zones.
At least it's so in both my delta and kappa.
T2 date setting is a bit tricky:
If you enter setting mode from normal display mode (time+date shown), you can only set the date and time for T1, even if T2 is on display.
To set the date for T2:
1. scroll to T1+T2 display mode,
2. press scroller to bring T2 to the first row (that is, "T1" is shown in the second row),
3. press scroller ~3s to enter setting mode,
4. et voilĂ , now you can set both date and time for T2.
If you enter setting mode while "T2" is in the bottom row, you can only set the time for T2, but not the date (this is called "quick set" in the manual).
It does make sense to have a separate date for T2 to make the day change over at midnight according to T2, not T1.
But I don't know why there are 2 different T2 setting modes...
BTW I use T1 for normal time and T2 for DST. So DST switchover is as simple as "scroll one step reverse, press scroller, scroll one step forward - done"
your_man_in_Hamburg
: The Ventura Code?
Post23 Feb 2010, 20:59
Gasp! It can't be, yet it was... ...an RTFM question! Sorry guys.
I suppose modern communications have shrunk earth to just 24 time zones today. Originally, you would have to be prepared for time zone differences sometimes as large as a couple of decades.
Return to Modern Digitals
