It is currently 04 Jun 2024, 16:03
1972 P2
primepulsar
1972 P2
Post26 Sep 2015, 12:54
Does any one know roughly how many P2's were produced in 1972? Thanks for the help!
Re: 1972 P2
Post26 Sep 2015, 21:55
Unfortunately, there's no way to pin that down with any certainty. We have no production records, so there's little to go on, other than bracelet date codes (which are questionable, at best) and serial numbers. Earliest bracelet code I've seen is 6-72 (two months after the release of the P1). Given the total production of about 135,000 units (with serial numbers starting at 10001, with highest number I've seen at 147xxx), I'd guess about 35-40 thousand were 1972 products. Of course, all this is subject to revision in the light of new information, should it become available. The Date/II is also, strictly speaking, a P2, but, as none were produced in 1972, aren't relevant in this context (10-15 thousand produced, judging by their relative frequency of appearance, compared to the "standard" P2).
holly35
Re: 1972 P2
Post12 Feb 2016, 19:20
bruce wegmann wrote:Unfortunately, there's no way to pin that down with any certainty. We have no production records, so there's little to go on, other than bracelet date codes (which are questionable, at best) and serial numbers. Earliest bracelet code I've seen is 6-72 (two months after the release of the P1). Given the total production of about 135,000 units (with serial numbers starting at 10001, with highest number I've seen at 147xxx), I'd guess about 35-40 thousand were 1972 products. Of course, all this is subject to revision in the light of new information, should it become available. The Date/II is also, strictly speaking, a P2, but, as none were produced in 1972, aren't relevant in this context (10-15 thousand produced, judging by their relative frequency of appearance, compared to the "standard" P2).
interesting,so a sub 14000 serial number would indicate an earlier model from 72 possibly.
