It is currently 10 Dec 2025, 05:56
Speaking of modern LED:s...
RedLEDsRule
Post19 May 2008, 14:28
Has anyone heard of this? Module or make, hehe? Looks kind of nice to me but with the dots instead of segments it´s not super. What do you think? // J
DKNY Men's Steel Watch NY3643
Type: FASHION
Movement: Quartz
Crystal: Mineral
Dial: Black
Case: Stainless steel
Case diameter: 38mm
Case thickness: 7.5mm
Water resistance: 50 meters
Bracelet/Strap: Leather Straps
: Speaking of modern LED:s...
Post19 May 2008, 23:02
I don't really like these dotted displays.
This model also exists/existed with "classic" segments, NY3636 (stainless steel) and NY3637 (gunmetal). But I don't know anything more about it.
RedLEDsRule
Post21 May 2008, 13:46
Really? When I looked at them it looked like dots.
http://www.superchrono.com/index.php?ma ... cts_id=597
or
http://www.superchrono.com/index.php?ma ... cts_id=586
Are you sure? Any other links or pictures?
Post21 May 2008, 14:32
Your links show dots, definitely.
I have some older images in my archive that look rather like lines:
RedLEDsRule
Post21 May 2008, 20:44
They look a bit suspicious, don´t you think? Especially the first one with the numbers sloping down to the right...
Some photoshopwork perhaps.?!
Re: : Speaking of modern LED:s...
Post21 May 2008, 23:06
RedLEDsRule wrote:They look a bit suspicious, don´t you think? Especially the first one with the numbers sloping down to the right...
Absolutely, contrast enhancement for the LEDs at least.
But if you look at the first one, the top segments are perfectly aligned with the background structures, looks like the module inside isn't correctly aligned.
The digits seem to float in front of the display, but that's probably because of the magnifier.
I'd love to see ONE manufacturer's photo that shows te ACTUAL item, non-photoshopped.....
Return to Modern Digitals
