It is currently 08 Oct 2025, 02:09
Correct module for Sicura?
Post23 Mar 2010, 22:40
I need the correct module for this watch, it does have a module fitted but I'm pretty sure it is not original - the display is very low
and the module doesn't appear to fit inside the case as it should.
Would anyone have a spare module to sell or if anyone knows which other models (if any) used the same module I could keep a look out for one on eBay.
: Correct module for Sicura?
Post24 Mar 2010, 04:01
Mick:
What's the movement size and button position. Many manufacturers made modules in "display centered" and "display offset" variations. Hughes, NS, Frontier and Fairchild for starters.
Post24 Mar 2010, 04:05
One command button at 2 o'clock, set button at 3 o'clock, the module measures 25mm.
Photo of the module (apologies for the poor quality)
Re: : Correct module for Sicura?
Post24 Mar 2010, 04:25
bucko170 wrote: the module measures 25mm.
And there's the rub(problem).
Post24 Mar 2010, 04:27
:cry: Doesn't sound to promising :evil:
Post24 Mar 2010, 04:42
Well, I looked at anumber I have here and all seem to be centered display on 25-26mm, with the exception of one white chassis Hantronix....
Bummer, cool case. :cry:
Post24 Mar 2010, 04:44
Would that one work?
Photo showing button layout
Post17 Jun 2010, 17:10
I'm still looking for the correct module for this watch, if anyone comes across anything could they please let me know.
Thanks Mick.
funkyguy
Post17 Jun 2010, 18:51
mick.
ive just checked my sicura module.
it appears to be the same as yours.
the display is also correct.
check peter wenzigs site and his sicura pictures .
same display arrangement.
module should have a small nipple which helps sit the module snug into the case.
FG
Funkguy
Post17 Jun 2010, 20:46
Thanks FG.
The module fits OK but it is not the original one, there are no lugs on the outside of the plastic housing to line up with the grooves at the 12 and 6 o'clock positions and more tellingly it has had some solder work done on the display contact to make the command button reach, this is most evident in the first photo.
I would be curious to know where the display sits on the original module, is it off-set or across the centre?
