It is currently 08 Oct 2025, 02:09
module required - either buy or trade.cheers.
funkyguy
Post16 Oct 2010, 20:21
hi all
iam seeking this module.
i can offer £25 or i have several hughes modules.nsc module.frontier etc for a trade.
any help would wonderful.
or evan a alternative module. would be helpful.
any help guys.? ta.
26/7mm wide
5/6 mm thick
cheers all.
FG
Funkguy
: module required - either buy or trade.cheers.
Post16 Oct 2010, 23:47
What make of watch is this module from, can you post a picture of the display side.
funkyguy
Re: : module required - either buy or trade.cheers.
Post17 Oct 2010, 17:44
Klippie wrote:What make of watch is this module from, can you post a picture of the display side.
hey klippie
here you go.
see above for pic.
its from a unbranded european led watch.
i do know these modules are used inside, junghans time commanders and other european leds.
i hope some can help me.
cheers to all.
FG
Funkguy
Post17 Oct 2010, 18:04
These modules are a nightmare the slightest hint of battery acid and they die not easy to work on either, good luck with your search...
funkyguy
Post17 Oct 2010, 18:07
Klippie wrote:These modules are a nightmare the slightest hint of battery acid and they die not easy to work on either, good luck with your search...
cheers..ill keep me eyes open.
any help guys.? ta.
26/7mm wide
5/6 mm thick
cheers all
Funkguy
Post17 Oct 2010, 20:24
That's a Fairchild module. In some watches a Commador module can be used, but only some - the Commador has bulging magnifiers over the display, so it makes the total module too deep for many cases. Darn shame.
I second all previous comments on the Fairchilds fragile nature.
Post17 Oct 2010, 21:36
retroleds wrote: the Commador has bulging magnifiers over the display, so it makes the total module too deep for many cases.
I recall having a commodore that didn't have magnifiers over the display, if I remember correctly it also had a 24hr display and was stamped on the case back as made in the USA?
Same type model as here -
http://www.ledwatches.net/photo-pages/commodore2.htm
Post18 Oct 2010, 16:48
Yeah, there are a few of those, but so rare to find I didn't think worth mentioning. I think I've seen/had two in hand. :-|
