It is currently 19 Oct 2025, 16:12
Pulsar P3 date/command date set problem
egomon
Post05 Mar 2011, 19:19
Hi. I have P3 date/command and after heating the module several times I managed to get a life back in it. but there is a problem. The minutes setting is working perfectly but the hours/date settind does not work. The problem is not in reed switch ( it is working).
Is it repaireble. :-?
I have a mens dress model with the same issue and after a month or so it started to work on its own. ;-)
Does enyone know what the problem might be? Is it repaireble or do I just have to wait until fresh batteries do its job and the module "learns" again what it should do?
Regards
Egon
: Pulsar P3 date/command date set problem
Post05 Mar 2011, 20:11
Should I return a SASM25 with your Synchronar movements? Hanno :)
