It is currently 08 Dec 2025, 14:12
New addition - LED Calcu-Pen / manual & box
s_elias
Post01 Mar 2013, 07:25
Purchased a working Calcu-Pen /w box & manual. Both ink refills are dry however
Cool LED pen
Re: New addition - LED Calcu-Pen / manual & box
Post02 Mar 2013, 14:40
Nice :mega:
Pity it wasn't produced with a watch function. I am still looking for refills for mine too.
Post02 Mar 2013, 19:06
nice clean one...i wonder if there are other from other manufacturers?
s_elias
Post06 Mar 2013, 07:50
I have another one coming soon, I'll that a few pics of that one.
Also I have an idea on the refill, I'm going to try a test tomorrow.
I think if you take a D2 multipen refill and snip the majority of the body, leaving the nib it might work. It appears to be the right diameter. I was going to plug the end with putty or a glue stick so it doesn't leak out.
I post a few pics if it works out.
s_elias
Post07 Mar 2013, 19:38
Just reporting back on the refill for the Calcu-Pen - Great News !! it works.
If you take a modern ballpoint refill for a multi-function or mini pen the diameter is the same it's just too long.
Measure the new refill against the old refill, mark and snip. I used a glue stick to seal the end, I guess you can use putty or something else.
The biggest challange is keeping the roundness of the refill when cutting. I had to use pliers to keep it back into shape, however next time maybe a plumners copper pipe cutter (small one) or a dremel tool would do less damage to the shape ~:(
Just reinsert into the pen your good to go with your new refill and it looks good ! You can even pick a color or use a highlighter refill.
Post08 Mar 2013, 22:44
Good job. I had explained my technique a few years ago - same starting pont as you on the refill but I throw it in the freezer. THen cut with the small, roller type tubing cutter. Scoop out some of the ink at the end, give it a little clean with isopropyl alcohol and fill end with some 5 minute epoxy. Yeah, damn shame no clock function, but then they would be double the price. :grin1:
Post06 Apr 2013, 00:54
I did retro leads suggestion on both my restored calcupens. Worked perfectly.
Here is a link so you can see the inside of the pen. Required the removal of the bezel surrounding the keypad. This exposed two screws which anchor the plastic nib in place.
http://www.hpmuseum.org/cgi-sys/cgiwrap ... ead=134685
Scroll to the bottom of the post.
Geoff
