It is currently 21 Oct 2025, 14:02
How To Get Smooth Pushers On Old Watch
wzy-hman
Post05 Dec 2013, 08:18
Hi, Im wondering if anyone can offer some practical advice/suggestions on best techniques to revive sticky pushers on old LCD watches in general. Im thinking for early-mid 70s watches like Casio, Fairchild, Microma, National Semiconductor, Seiko, TI, Timex, etc. Im assuming there isnt a big difference between the brands but that might just be very naive.
When the pushers are sticky and/or getting stuck in the indented position (so you need to pull the pusher back out to get it to its normal/original position), what are the best ways to go about trying to restore them to smooth operation?
Ive tried looking around the forum and didnt find anything specific, however, apologies if this actually has been covered somewhere. Any views/ideas/suggestions gratefully received! Thanks in advance
Re: How To Get Smooth Pushers On Old Watch
Post05 Dec 2013, 10:50
A good ultrasonic clean (module removed first obviously) followed by the application of a lubricant usually does the trick.
I used to use a watch oil to lubricate the pushers but I have been advised that some oils can degrade the rubber seal inside the pusher and a silicone spray would be a better option.
wzy-hman
Post05 Dec 2013, 11:40
bucko170 wrote:A good ultrasonic clean (module removed first obviously) followed by the application of a lubricant usually does the trick.
Thanks for your insights, I have a few follow-on questions:
- Silicone spray ie WD-40? Do you just drip a bit onto the pusher and let it drip inside? Or full on spray? (also, if the case is coloured base metal eg gold tone, then is there risk the colour gets stripped?)
- I currently have zero knowledge of ultrasonic cleaners. In the context of mechanical watches, it generally seems its best for bracelets only. Can you steer me to the sorts of (economically priced) models that might be suitable for use on an LCD watch case? And also is there any specific type of cleaning solution that's preferred?
- And are there any alternatives to an ultrasonic cleaner that can be almost as effective?
Sorry for the mass of questions, I have a lot to learn!
Post05 Dec 2013, 13:35
I take a Silicone Spray. My wife had it already before we met the first time, so I paid 0,00€ for it. Needless to say she doesn´t use it at all*
Seiko Kid
Post05 Dec 2013, 14:43
This is bar far the best option ( and its for any watch type )
http://www.ebay.co.uk/itm/Seiko-SILICON ... 1e82d57412
You can by it for £5 at a watch supply store but for a "click and deliver" to your own door , this is probably cheaper
Post05 Dec 2013, 18:02
Seiko Kid wrote:This is bar far the best option ( and its for any watch type )
I have been looking for a suitable product for myself, do they do anything similar as an oil? Oil would be easier to work it's way into a sticking pusher than grease.
wzy-hman
Post05 Dec 2013, 18:13
I actually have some of this lying around somewhere. How does one "work it" onto a sticking pusher? Any particular technique beyond just trying to pour some into the base of the pusher where it is protruding from the case?
Seiko Kid
Post05 Dec 2013, 18:17
I always thought oil was for the mechanism of a mechanical. have a viscous product on a switch ( even in my electrical day work ) isn't right. You need something that sticks and doesn't run
If its still sticking then shave a gnats hair off the pusher gasket with a craft blade
Seiko Kid
Post05 Dec 2013, 18:18
you can't "pour" grease !
wzy-hman
Post05 Dec 2013, 18:23
you can't "pour" grease ![/quote]
Yes, agreed. I meant try to poke it in with a pin or something ie how would it be applied in a meaningful way?
wzy-hman
Post05 Dec 2013, 18:27
Say I have a watch case with two buttons on the right at 1pm and 5pm, if they are sticky then how do I go about shaving a slight hair off the pusher gasket? Sorry, this might seem v elementary but Im a total noob on this. Feel free to direct me towards any info that you think already covers off all this. Thanks!
Seiko Kid
Post05 Dec 2013, 19:39
you have to dismantle the watch. take the back off, remove the module. then remove the E clip from the inside end if the pusher ( if it has one ) and pull out the pusher - then clean and work on it
some watches the pusher is just inserted from the inside but this is uncommon
it's likely it's just dirty
wzy-hman
Post06 Dec 2013, 02:06
Seiko Kid wrote:you have to dismantle the watch. take the back off, remove the module. then remove the E clip from the inside end if the pusher ( if it has one ) and pull out the pusher - then clean and work on it
Excellent, you gave me the hint I needed - thanks. Googling "watch pusher e clip" brings up some v detailed instructions. Sorry, I truly needed something that elementary ;-)
Users browsing this forum: No registered users and 53 guests
