It is currently 04 Mar 2026, 04:03
Correct Crystal For Seiko 0634-5019 Needed
srgalpin
Post04 Feb 2015, 10:22
Hi All,
I have a Seiko 0634-5019 that needs a new crystal to get it looking back to new.
From looking around, I believe the correct replacement crystal is part no. BA0V18GNT.
What I want to know is, do all of the 0634 models have the same crystal?
I have found someone who has a BA0V20GNT0 crystal available, which I think is for the 0634-5009.
Would this crystal fit my 0634-5019, or does it have to be the BA0V18GNT only?
If anyone has the correct crystal available, I would be interested in buying it as well.
Many thanks in advance.
Scott
Re: Correct Crystal For Seiko 0634-5019 Needed
Post04 Feb 2015, 10:49
Scott only get the correct crystal. All the 0634s have different case designs and different size crystals.
srgalpin
Post04 Feb 2015, 13:38
Hi Adam,
Thanks for the reply.
Are you able to confirm that the BA0V18GNT is the correct crystal for this model?
Cheers
Scott
Post04 Feb 2015, 13:48
According to my 79 casing parts list thats the correct number. Good luck with your search.
srgalpin
Post04 Feb 2015, 13:52
Hi Adam,
Thanks for the quick response!
One final question.
With the 0634-5019, there appears to be two versions. One with a plain screen, and another with the chronograph part separated by black outlines.
Am I right to assume, that there were two versions of this model, and that the crystal for both is the same?
If not, I have bought one with the black surrounds around the chronograph, with the back case saying 0634-5019, so is the BA0V18GNT the correct crystal for this model assuming it has the correct case back?
Thanks again
Scott
Post04 Feb 2015, 14:13
My casing list is not that helpful with the lcd panels. It does state that there are two for the 5019, but as it doesnt list a 5000 that does use a segmented lcd panel I cant cross reference. The crystal will fit either so thats not a problem.
Anyone else confirm what lcd panel should be with what 0634 so I can make sure the library is correct.
thanks
Users browsing this forum: No registered users and 118 guests
