It is currently 04 Mar 2026, 04:02
Sicura VIP 2000 - 389 size rechargeable cell battery
wzy-hman
Post12 Mar 2015, 04:14
Hi, I wondered if anyone had managed to try a new Maxell XR11630W Rechargeable (by Hitachi Maxell Ltd, Japan) on their Sicura VIP 2000. I think it should do the trick as a replacement battery
....... [edit] I may have an answer to above as just came across a posting where someone used a Varta MBU20 NiMH as a substitute, albeit on a different watch (a 1976 Crystron Solar). Am ordering one and will post results here after I try
Re: Sicura VIP 2000 - 389 size rechargeable cell battery
Post13 Mar 2015, 15:58
Could I ask where you're ordering it from? I spent ages trying to find a rechargable 389 for mine but didn't come up with anything.
Post13 Mar 2015, 17:55
I don't think a NiMH rechargeable will work in a Sicura VIP2000 as the cell voltage is only 1.2 volts and the watch circuit has a low battery alarm function that kicks in at about 1.4 volts (display starts flashing).
Post13 Mar 2015, 17:59
And again- the Maxell XR11630W is a Lithium Titanate cell with a nominal 2 volt rating- only 5 cells in the Sicura array so absolute maximum output would be 2 volts (more usually around 1.6 volts output) which isn't enough to charge the cell. Interestingly the earlier Sicura Solar Quartz digital had a 7 cell array so could use this type of battery.
wzy-hman
Post13 Mar 2015, 18:34
You might want to wait until I've tried it as its due to arrive in around 10 days time and the batteryis only 1.2V rather than the original cell's (I believe) over 2V or a 389's 1.5V
Here's a link to the battery
http://uk.farnell.com/varta/55602101501/battery-nimh-15mah-1-2v/dp/1902509H
Users browsing this forum: No registered users and 89 guests
