It is currently 18 Oct 2025, 18:30
How to repair Seiko 0624 crystal ?
Pulsar77
Post07 Feb 2018, 03:07
Hello,
I have just bought this beautiful Seiko 0624, but the crystal has some scratches.
1) Is it possible to erase the scratches with the Polywatch ? I don't know it the crystal is in glass or plexiglass...
2) If it's noy possible to erase the scratches with the polywatch, is it easy to change the crystal ?
Thank for your help.
Digital LCD & LED watches fan
coconutman351
Re: How to repair Seiko 0624 crystal ?
Post07 Feb 2018, 10:40
Given that this is a Seiko Quartz brand I highly suspect the face should be a mineral crystal. The best way to check is to tap it and listen if you have a high frequency most likely it is a crystal, if it has a dull sound it's plastic. You can also check by its reflection. A plastic will have a warped reflection where as a crystal will have a non-distorted reflection. Regarding the finishing, if it is a mineral glass you it would be best to remove the crystal from the watch or mask off the steel area. I usually use a 1000 grit wet sand paper and slowly grind away the crystal until all the deep grooves have been removed. It takes patience however it does payoff dearly if you can't find an new old stock replacement. I finally finish it off with Cerium Oxide (glass polish). Again, takes a lot of time and muscle power, however you are paid off with a perfect crystal. Make sure the crystal is flat on the wet sand paper, you don't want to start beveling the sharp edges. Removing the crystal from the case could also help with the case restoration work as well.
Nice watch and a great find!
Good Luck!
Robert
Pulsar77
Post07 Feb 2018, 13:26
Hey,
Ok, I will see when I received it...
Thank you.
Pip
Post08 Feb 2018, 19:13
I have also tackled a few Seiko crystals with some success. I start with 1000g sand paper and work down to 2400g I think it is. The I swap over to diamond paste working my way towards the fine ones which I use on an old leather belt. (Belt flat on the table, paste on the belt and hold the crystal flat on it making circles). If you do with the the tv or something on it doesn't seem so bad!
One other tip - I use a smallish plastic sucker (I have several sizes, they were about 10p each) to hold the crystal, saves my fingers a lot of grief.
Good luck with it and post up some after pics too. Oh, and a quick search shows that the crystal is not too hard to find NOS, will most likely be around $30/40
Pip
coconutman351
Post10 Feb 2018, 07:01
I agree to follow up with the 2400 g wet sandpaper to remove the rough scratches from the 1000g paper. I never thought about using a suction cup to hold the crystal. I've had many events where I used my hand to hold the crystal only to have my skin being sanded down!
Pulsar77
Post10 Feb 2018, 10:06
Hello,
I just found this on internet, it’s a new Polywatch product for glass, has anyone ever tested ?
vespa78
Post24 Apr 2018, 20:14
Pulsar77 wrote:Hello,
This looks interesting. I have made very good experience with the small Polywatch Polishing Tube.
the Font on this Advertising looks different, but I guess it's the same Brand since both Products are from Germany
anyone bought the Syringe-Set so far?
coconutman351
Post24 Apr 2018, 20:26
I have not used this, however in order to remove any crystal scratches you will need to sand down the entire surface if you want to remove all scratches and have a flat crystal surface. Just polishing the affected area could create an uneven finish, like a polished pot hole on your crystal. Hopefully this is not one of those "as seen on TV" super magic scratch remover for cars and watches! In my opinion it will take some patience, sweat and dedication to get that perfectly smooth restored crystal finish using the old school methods of wet sanding an progressive polish finishing steps.
Pulsar77
Post25 Apr 2018, 00:15
coconutman351 wrote:I have not used this, however in order to remove any crystal scratches you will need to sand down the entire surface if you want to remove all scratches and have a flat crystal surface. Just polishing the affected area could create an uneven finish, like a polished pot hole on your crystal. Hopefully this is not one of those "as seen on TV" super magic scratch remover for cars and watches! In my opinion it will take some patience, sweat and dedication to get that perfectly smooth restored crystal finish using the old school methods of wet sanding an progressive polish finishing steps.
you’re right because I tested this product and it works only on very light scratches
