It is currently 18 Oct 2025, 18:33
Otron released in 1976-7
Post03 Sep 2018, 13:12
Just got this one yesterday in non working conditions at my favourite flea market due a battery leakeage over the batt. connector.A simple watch that has only time,date,chrono split and light.
The bad is the band not sizeble....no links to remove....
Re: Otron released in 1976-7
Post05 Sep 2018, 10:15
Hi guys,just to add further info about this module. I was thinking of having already seen that module before somewhere,but where?? Surfing over the net i found the answer: the Otron module is a very very good clone of the most famous and expensive Omega Cal. 1620. You judge:
The Chrono mode is activated by pressing 3 times the chrono button,like the Omega 1620. Functions are: 1) start-stop 2) split 3) lap 4) spilt-stop
In the chronograph mode 7 arrows (similar to the Omega but not the same) appear and after a split or a lap display, they blink during 7 seconds.
Like the Omega the Otron can show the date instead the seconds (Omega use DATE Otron use DT)
Well in the time keeping mode you can run the chrono and a ST is blinking beside the minute (in the Omega is a "star"). To stop the chrono you have to simply press "stop" and the watch memorize the time that you can see pressing 3 times the chrono button.
PS: the crystal shows the same days layout with an arrow
That's all,you judge ~:(
Post05 Sep 2018, 10:47
Good find Simone and well written up. The 1620 is quite a robust module but I wonder if this could be used a replacement module? Although these Otron are pretty scarce too.
