It is currently 23 Apr 2024, 18:51
0674-5009 resto
0674-5009 resto
Post22 Mar 2016, 01:55
Got some before pics and after. Cost $55Usd
1) watch pitted, scarred and over polished. Covered in grunge DNA,
2) display stuck on date and unresponsive to pushers.
3) setting crown stuck in not set mode.
4) Crystal severely pitted.
1) new crystal installed.
2) upper case refinished with brushed sides, polished shoulders.
3) lower case refinished in brushed with circular brushed on battery hatch.
4) pushers cleaned, polished and new gaskets installed
4) movement disassembled, cleaned and reassembled, oiled on setting mechanism, cleaned pusher rocker contact.
Before:
After, did I have to label them :scratch:
This is fun!
P.S. Does anyone have the strap number. I placed a similar style but the original deployment clasp does not flare at the lug.
Geoff
Re: 0634-5009 resto
Post24 Mar 2016, 11:21
great restoration...that took time. But it's look new and shiny now and that the reward. :-D Super :-D
Seiko Kid
Re: 0634-5009 resto
Post30 Mar 2016, 06:48
Looking good Geoff
cte
Re: 0634-5009 resto
Post18 May 2016, 23:56
Lovely job. :grin1:
Re: 0634-5009 resto
Post19 May 2016, 06:45
Thanks all!
Fun to wear also. The proportions are just right.
Geoff
jringo8769
Re: 0634-5009 resto
Post04 Dec 2016, 06:30
great work...very well done...
Pulsar77
Re: 0634-5009 resto
Post09 Feb 2019, 15:10
Hey,
How do you brush the case ?
Digital LCD & LED watches fan
Re: 0634-5009 resto
Post11 Feb 2019, 01:43
I use wet/dry 400 grit sandpaper and a straight edge to “brush” the case. Crystal removed of course.
600 grit for a finer brushed finish.
Straps get the same treatment making sure all strokes are parallel. I finish the strap off with scotch bright.
Pulsar77
Re: 0634-5009 resto
Post11 Feb 2019, 16:37
767Geoff wrote:I use wet/dry 400 grit sandpaper and a straight edge to “brush” the case. Crystal removed of course.
Ok, thank you very much.
And to do a mirror polish on the edges, how are you doing ?
Re: 0634-5009 resto
Post11 Feb 2019, 17:11
Fab work
Re: 0634-5009 resto
Post11 Feb 2019, 18:38
Fantastic case work Geoff. Change the title to 0674 so if anyone looking for this watch and what can be done finds this thread.
Re: 0634-5009 resto
Post11 Feb 2019, 19:22
Ooooops, typo, shouldn’t post at midnight!
Edges sanded first to remove major dings with wet dry 400, 600, 1000 grit. Then polished with metal polish “weenol” and Dremel. Try to keep the edge from rounding with the polish wheel.
Then the brushed finish is applied with parallel strokes as described.
See this article about the Glycine airman restoration I did in 2006:
http://www3.telus.net/public/geoffqf/glycinerepair.doc
Omega 300 restoration:
https://forums.watchuseek.com/f20/basket-case-omega-300-resto-879245.html
Re: 0674-5009 resto
Post11 Feb 2019, 20:41
Love the Omega 300 and a fantastic job in the restoration too. Such a simple strong design. Added to my wishlist. [EDIT] Just seen the prices of the Omega 300, I think it will be staying on my wishlist for a very long time.
Re: 0674-5009 resto
Post11 Feb 2019, 20:50
Cost me $350USd at a flea market. That’s the fun, turning it into something gorgeous!
Pulsar77
Re: 0674-5009 resto
Post12 Feb 2019, 20:49
Thank you very much for sharing experience, it’s not easy to find this restore technics :Prost:
Pulsar77
Re: 0674-5009 resto
Post12 Feb 2019, 20:59
I found a discution where a man repair a Seiko dead module with a mild hydrochloric acid solution. This product clean the oxydation and repair the welds, after the dead module run ...
https://www.thewatchsite.com/34-watchma ... ics/306546
I never see that is possible to put a dead module is a solution and after it runing, is it really possible ?
Pulsar77
Re: 0674-5009 resto
Post15 Feb 2019, 19:10
767Geoff wrote:Cost me $350USd at a flea market. That’s the fun, turning it into something gorgeous!
Hey,
Actualy I renovate my 0634 and I would like to know how is possible to do the circular satin on the push button as the photo ?
I saw that you did that on the case back to your Glycine and Seamaster 300.
Re: 0674-5009 resto
Post16 Feb 2019, 12:11
Just get the pin out of the watch...clamp it in your dremel and hold some 600-1200 grade sandpaper to it. :-D
Pulsar77
Re: 0674-5009 resto
Post16 Feb 2019, 16:43
Kasper wrote:Just get the pin out of the watch...clamp it in your dremel and hold some 600-1200 grade sandpaper to it. :-D
Thank you Kasper, it works perfectly :Prost:
Before, a hold mirror polish maybe during a service
I put the button pusher on the dremel drill and I used sand paper k600 and speed 4
And the result :mega:
Thank you everybody for the help, I love definitely this forum :dwf:
Re: 0674-5009 resto
Post16 Feb 2019, 20:00
Sorry Pulsar77,
Was in Beijing and for some reason DWF forum was blocked by the Chinese.
Jasper nailed it, or rather chucked it :scratch:
Cheers, Geoff
Pulsar77
Re: 0674-5009 resto
Post17 Feb 2019, 00:05
767Geoff wrote:Sorry Pulsar77,
Cheers, Geoff
No problem, but thank you for your sharing
I found this review where a man repair a Seiko dead module with a mild hydrochloric acid solution. This product clean the oxydation and repair the welds, after the dead module run, is it possible ? I never saw that before :scratch:
Towards the end of the page :
Re: 0674-5009 resto
Post17 Feb 2019, 01:18
Yes, but I use white vinegar. Milder then the HCl. Also, while good at removing oxidation and copper sulphate residue it can remove any remaining contact under the corrosion resulting in an open circuit.
Also, do not immerse the LED or LCD module.
Another concern is neutralizing after acid application. I use baking soda and water for the neutralizein* followed by a water wash, then isopropanol followed by drying.
Sometimes a dental pick for GENTLY removing corrosion an/or fibre glass pen.
After all the above is completed I coat the circuits with DeOxit red; a deoxidizing oil which also protects and is non conductive. Especially good for creeping underneath ICs.
Geoff
