It is currently 17 Jun 2026, 11:36
Seiko LC Quartz 0624 / 0439 glass
Post20 Mar 2014, 15:09
Does anyone know if the crystals (glass) on 0624-5009 and 0439-5009 are interchangable?
(They look similar but these things are rarely so straight forward).
retrowrist
Re: Seiko LC Quartz 0624 / 0439 glass
Post20 Mar 2014, 16:27
The 0439-5009 is fixed to the bezel, and cannot be removed without force, where the 0624-5009's is removable because it is a separate part.
Hop this helps.
- Patrick
Seiko&Casio Lcd's
Post20 Mar 2014, 20:18
Short anwser,
No ,it doesn't fit for the reasons retrowrist already stated.
Post20 Mar 2014, 21:40
Many thanks for the replies - had a feeling that would be the case. Back on with the hunt for a good 0624 crystal then...
Post20 Mar 2014, 22:47
is it broke or badly scratch?
Seiko Kid
Post21 Mar 2014, 08:01
Actually theres some misunderstanding here
The 0624 is mounted on a brass frame that also houses the buttons. It is heavily glued onto that frame but! it can and has been known to separate
The 0432 is a stand alone glass that is pressed into the case - I would not suggest removing this glass unless you have a lot of time and patience - experience with this model
I have a few used 0624 crystals, new is not possible anymore
I know I guy who can polish them but because of the size the edges can be slightly over bevelled . also I am able to get new crystals cut, kasper can also do this but you need a specific thickness etc
retrowrist
Post21 Mar 2014, 15:44
Seiko Kid wrote:The 0432 is a stand alone glass that is pressed into the case - I would not suggest removing this glass unless you have a lot of time and patience - experience with this model
Hi Seiko Kid, and thanks.
Actually, you can remove the 0432 crystal from it's bezel if you apply direct heat from a hairdryer, and then push from the inside with preferably a "wooden" bamboo stick or some thing close to that. You would want to have the bezel in a movement stand while doing it. I have had good success with this, and am usually able to salvage the retaining gasket. Once removed as described, you have two choices: polish the existing crystal with sandpaper and other polishing materials, or two, have someone like Kasper cut a new piece of glass.
Anyway, I hope that helps a little.
- Patrick
Seiko Kid
Post21 Mar 2014, 15:50
Patrick, your getting your watch models the wrong way round
retrowrist
Post21 Mar 2014, 16:28
Seiko Kid wrote:Patrick, your getting your watch models the wrong way round
Seiko Kid
Post21 Mar 2014, 16:29
0432 the glass is not on a bezel. it push fits into the case with the aid of a rubber gasket like most other models
retrowrist
Post21 Mar 2014, 16:33
Ok, I see, my mind is correct, but my description of the objects were wrong. I am sorry, and I will correct this in case I need to make further posts of this in the future.
Thank you, Seiko Kid,
- Patrick
Post21 Mar 2014, 23:28
In answer to Kaspers question mine is badly scratched - probably beyond refinishing.
Thanks again for the answers - I've got Seiko lcd's with glass that matches both of these descriptions so it all makes perfect sense.
Seiko Kid
Post21 Mar 2014, 23:41
I'll post some pics of the used ones I have and let's see if there is something that may be good for you ?
Post23 Mar 2014, 01:06
Thanks for the kind offer Seiko Kid (and very much appreciated) but to be honest this 0624 is so rough that I think I'm going to just retire it to the spares box.
Users browsing this forum: No registered users and 38 guests
