It is currently 23 May 2024, 08:34
Bracelet Adjustment on Pulsar LCDs
Post30 Jan 2008, 08:14
Has anyone got any idea what can be done to adjust the mesh bracelet on the Pulsar LCD Dress models (5140 and 3140).
I have skinny wrists, and have made the bracelet as small as possible via the clasp adjustment, but it's still far too large. Do I have to lift weights so that I am able to wear this model ?
: Bracelet Adjustment on Pulsar LCDs
Post14 Feb 2008, 12:07
as far as I remember the mesh bands were made in two or three sizes as the clasp adjustment is only for fine tuning
Post14 Feb 2008, 16:24
Unsolder the clasp connector(pulls right off when hot enough), fill the mesh of the band with silver solder at the area where you want to cut it - this stabilizes the mesh for sawing with a fine jeweler's saw. Resolder clasp connector on, sopping up any extra solder on outside of mesh with solder-wick. Great job for small "pencil flame" butane torch(get one that stands upright with the flame coming out horizontally).....propane torch is too big, soldering iron can't create enough heat.
:idea: Cut it slightly long so you can conceal your handywork within the clasp. :-)
Other [saner] alternative - buy another band that is shorter and put the Pulsar clasp on it. That is just a standard springbar held band...unlike the LED Dress watch.
Post14 Feb 2008, 17:30
8-) that's a solution for Pro's only, Ed.
Re: : Bracelet Adjustment on Pulsar LCDs
Post14 Feb 2008, 18:11
azimuth_pl wrote:8-) that's a solution for Pro's only, Ed.
Not really, IMO. I think some of our members are very handy people who enjoy a challenge... :-) 15 minutes work if all goes well. A fine tooth jeweler's saw(or extra fine hacksaw) will do a neat job once the links are secured with the silver solder. Similar to cutting thin sheet metal with it between two pieces of wood to prevent ripping. 8-)
