It is currently 17 Apr 2026, 11:48
Timex LCD Watch Wanted
NormanS
Post01 Mar 2011, 16:19
Hello, I am looking to purchase a 1977/78 Timex LCD / SSQ mens watch in good to excellent condition. See photo below. Some were marked as SSQ others simply said Timex. Either is fine. Please let me know if you have one to sell.
You can contact me at n@normansizemore.com
Kind regards,
Norman
http://img828.imageshack.us/i/timexssq.jpg/
Lillegutt
: Timex LCD Watch Wanted
Post01 Mar 2011, 19:45
That lcd looks to have bleed or something going on. I have a few Timex here let me have a look to see if I have a good working version and i'll mail you.
NormanS
Post01 Mar 2011, 23:09
Thanks for the ebay link. I contacted the seller and he will not confirm that the watch actually works, but that is what I am looking for.
Lillegutt
Post02 Mar 2011, 00:16
Looking closer, it seems like DWL could be right. There is a shadow on the screen on the upper left corner. Guess you would be very lucky if the numbers light up on that one.... Possibly you could try to get a new module for it as long as the case is OK. But I have no idea which watches use the same module...
JHH
morelite
Post02 Mar 2011, 01:43
Is that the Timex model with tritium backlighting? It sure looks like the one I had that did.
NormanS
Re: : Timex LCD Watch Wanted
Post02 Mar 2011, 03:51
morelite wrote:Is that the Timex model with tritium backlighting? It sure looks like the one I had that did.
Hi, yes it had back lighting, by depressing the two buttons simultaneously. They also made the same watch without back lighting and only only push button.
Norman
mercurym
Post07 Mar 2011, 21:44
Norman -
I have both a ladies and mens SSQ, though I'm not sure of their manufacture date. Both work. Obviously, the mens is closest to your example. If it's what you need, let me know.
Uploaded with ImageShack.us
The Ladies model has some blocking in the right lower corner, but the Mens works fine. I know very little about these watches, other than they're pretty neat.
Lillegutt
Post29 Mar 2011, 15:32
A working one this time, if your'e quick with the BIN.
http://cgi.ebay.com/Vtg-1970s-Button-Ce ... 2562389ac3
JHH
morelite
Post30 Mar 2011, 03:31
Lillegutt wrote:A working one this time, if your'e quick with the BIN.
JHH
That is the tritium backlit model, notice the 3H on the back. I'm sure it no longer glows but the tritium tubes can be replaced.
morelite
Post30 Mar 2011, 03:35
JHH
Lillegutt
Post04 Apr 2011, 23:28
Another one.... A two button model this time...
http://cgi.ebay.com/Vintage-Timex-SSQ-L ... 500wt_1156
JHH
