It is currently 04 Mar 2026, 03:41
Seiko Alba Digital Analog - Help for Analog setting
ThePaolobraga
Post27 May 2011, 20:55
Hello Everybody.
Just buyed (not expensive watch) this Seiko Alba.
Uploaded with ImageShack.us
I was able to adjust digital watch, but i haven't find a way to set the analog.
Did someonde has this watch and can suggest me how to do ?
Thanks anyway
Led fevered
: Seiko Alba Digital Analog - Help for Analog setting
Post28 May 2011, 09:29
The setting instructions for the analog section are usually printed on the dial upper left! However, it looks like you may have a Japanese home market version and the instructions are in Japanese! It looks like the little diagram shows that you have to push two buttons simultaneously (upper left, lower right) and then use the upper right button to advance the hands. You could also try googling the caliber number- probably something similar to Y955. The watch was made by Seiko so possibly one of the Seiko ana-digi used the same movement but I cannot think which one offhand.
Post28 May 2011, 17:52
Its very similar to the Pulsar Y651
You can download the manual for the Y651 from my website digitalwatchlibrary.com here
http://www.digitalwatchlibrary.com/DWL/ ... y651-506a/
Hope it helps.
ThePaolobraga
Post29 May 2011, 09:44
Thanks Tom.
In fact, following instructions i was able to set lcd screen, but none happens to analog (probably i havent followed properly instructions).
Now i try another time using instructions linked by DWL (thanks another time) that looks really similar to my Seiko Alba watch.
I'll let you know.
I really appreciate your support.
Regards.
Led fevered
ThePaolobraga
Post29 May 2011, 10:05
WORKS !
Thanks for the third / fourth time.
Really effective suggestions guy.
Led fevered
