It is currently 27 Apr 2026, 15:17
CaseBack Butterfly Epoxy Repair?
Timecollector
Post15 Jun 2014, 21:27
I have a Stainless P2 that I have had for awhile and took it apart today to change out batteries and the Butterflies fell off the case back. It looks like they had been epoxied before and not very well. Either way does anybody know if the correct epoxy to reattach the butterflies is available. I would prefer to get ahold of the right stuff before I use off the shelf epoxy.
Thanks!!! :Hi:
Re: CaseBack Butterfly Epoxy Repair?
Post16 Jun 2014, 00:48
I've lost count of the number of times I've had to deal with this, but, there is a permanent solution (at least, as permanent as anything I've found). Time Computer clearly had the same problem, and ultimately went with spot welding on the stainless steel casesbacks, and with integral rivets on the goldfilled ones. Riveting worked well, but the spot welds create pits on the outside of the part (from the pressure of the electrode), which are unsightly and time-consuming to remove. I have seen improvised repairs that span the spectrum from a badly botched attempt at soldering, to airplane glue (on metal?!). The Pulsar Jewelers Manual recommends the use of some type of cyanoacrylate adhesive, but such fixes tend to be temporary, since the metal connector has substantial flexibility, and the cured glue has essentially none, and the bond ultimately breaks (so, here is a situation where the manufacturers' advice can, and should be, ignored).
The best repair I've come up with is some amazing stuff called J B Weld. It's a mix of high-strength epoxy, and powdered steel. I use the 5-minute version called J B Quick. The key to making this work right is to get the metal surfaces absolutely grease and oil-free. I'm not sure how alcohol got to be the preferred solvent for cleaning metal (aside from the fact that it's cheap and readily available), but acetone is at least ten times better at de-greasing metal, so it's worth the extra effort to get it. Not much adhesive is needed; about a third the volume of a paper match-head is enough. Spread it over the central two-thirds of the center of the connector circle, and once you've got the location right, press down hard enough to get a bit of the glue oozing up through the two holes (this will also spread the adhesive evenly over the entire circular surface). Give it a couple minutes to start hardening, then hit it with a hot-air gun (at 350-400 degrees F) for 10-15 seconds (with the airflow straight down). This will accelerate and ensure a full cure, and also briefly lowers the viscosity, allowing the two extruded blobs on top of the connector to flow and spread out a bit, effectively forming rivets! Done right, the result is as "factory"-looking as you could hope for, and it's a durable repair (I've done dozens, and have yet to see a failure). Any good hardware store should have the J B products, but if not available in your area, there is always eBay... :grin1:
BTW, on page 10 of the Pulsar Jeweler's Technical Manual, this little metal part is referred to as the "bow-tie" connector, so we should probably go with that, just to keep the terminology consistent.
Timecollector
Post16 Jun 2014, 00:58
Thanks Bruce. That is exactly what I was looking for. I have all the ingredients to do this. I have used JB Weld before, but not in such a small quantity and for such delicate parts. Thanks for such a complete write up!!! It really helps!!! :Hi:
Timecollector
Post16 Jun 2014, 23:33
OK, cleaned case and butterfly with Acetone (smooth clean surface), applied JB Quik and set butterfly in place. Heat gun applied for about 15 seconds (you can see JB weld sort of flow outward through those two little holes like you said making a rivet joint). Now its just drying time. Sweet!!! I will put it back together tomorrow. :Prost:
