It is currently 21 Oct 2025, 11:22
Another bleeding Seiko 0624 5009....
gallas27
Post13 Feb 2014, 11:15
Hi guys,
here's my Seiko 0624 5009, which I've bought some days ago for a very low price 8-).
Of course, it has the common problem of "bledding" display. Instead, the cosmetic condition is very good and it also has the original bracelet.
Here is my question ;-): the module seems to work, so the only thing I need is a new display panel. Finding the original display could be very difficult and expensive, so I am thinking to "swap" the display from another model. A similar model that I've found is the Seiko F039 5000, but I don't know if the display can be fitted on the 0624, which is very earlier.
What do you thnk :-D?
Thanks!
Re: Another bleeding Seiko 0624 5009....
Post13 Feb 2014, 18:16
No,you can't use the F039 5000 display....you coud try to search a not working 0624 or 0644 with a good lcd panel....or you can use a 0662 module with the 0624 panel in case your original module is dead :-P
gallas27
Post13 Feb 2014, 18:52
simone wrote:No,you can't use the F039 5000 display....you coud try to search a not working 0624 or 0644 with a good lcd panel....or you can use a 0662 module with the 0624 panel in case your original module is dead :-P
Thank you Simone (another italian here :o).
Do you think that the 0644 is more common than the 0624?
And what about the green film of the 0624? The 0644 does not have it :scratch:.....
Post13 Feb 2014, 19:03
Sorry for all the members forum....now i speak italian for a while...
Dunque sono entrambi molto difficili da reperire poichè modelli discretamente rari,tuttavia lo 0644 ha di certo quotazioni di gran lunga inferiori.
Per quanto riguarda la pellicola verde che vedi non ti preoccupare poichè non fa parte del display,è una semplice pellicolina che puoi comodamente riciclare dal tuo 0624.Quindi non ti preoccupare.
Purtroppo la serie F non va bene,il display è completamente diverso (ha anche caratteri alfanumerici oltre che avere dimensioni differenti)...
Ti consiglio di bazzicare un pò sulla baia e vedere se salta fuori qualcosa...ripeto sono pezzi un pò rari quindi porta pazienza...oppure puoi semplicemente chiedere nel forum se qualcuno ha un pannelo da vendere....se hai bisogno sono a disposizione....
That's all.....
gallas27
Post13 Feb 2014, 19:20
simone wrote:Sorry for all the members forum....now i speak italian for a while...
That's all.....
Thank you Simone for your answer (I'm not gonna speak italian 'cause I have to test my English knowledge :mega:).
I will try to find something on the famous online shop (I don't know if I can say the name, so I'm not gonna say it) but.....I have never got any patience so I don't know how it will be the research.
Anyway, I will ask the display on the forum for sure ;-)!
Post13 Feb 2014, 19:31
Ok ;-) ;-)
.....fai bene a parlare inglese,a volte però svalvolo e ne ho approfittato per scrivere in italiano...non capita tutti i giorni sul forum... :-P
